2006-06-28 10:07 PM - last edited on 2023-05-23 05:15 PM by Rubia Torres
2006-06-28 10:36 PM
2006-06-29 03:39 AM
Jay wrote:Jay,
I've done some more checking and it turns out that the D1 Metal 10 door always uses a 6' hole and always has the 6' by... text -- regardless of the selected size. Additionally, the D2 Metal 10 door always has a 5' hole and always has the 5' by... text, again, regardless of size...
2006-06-29 06:11 AM
2006-06-29 06:20 PM
Dan wrote:The first few attempts to make this error happen didn't work -- the doors looked just fine -- then it started again. You can see in the graphic below that the opening is about 7" too big on each side, yet the rough opening (which cannot be change) shows the correct dimension. There are no other "over"-type parameters to tweek.
Just a thought...check your "oversize" parameters and make sure they are set to 0"
