gdford
Door Jamb rough opening space in Section
Is there any way to hack the door settings so that in section the rough opening space shows as a separate fill from the door frame?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
2 Replies 2
Lingwisyer
Guru
Given all the relevant parameters are accessible, you could possibly create your own host object that draws a polygon within the rough opening space which can then be coloured via its section attributes
gdford
I appreciate the information - but that's more of a hack than I care to dig into.
Archicad has consumed almost as much of my life since version 10 as I have slept since then.
Enough is enough.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
