We value your input!
Door and Window Tag Properties
mikoto06
This might be a silly question, but is there a way to change how the line breaks happen with door & window tags in Archicad 25? For example currently it sets up as:
ID/Unit Dimension/Fire Rating/Acoustic Rating
but I would like:
ID Unit Dimension/Fire Rating Acoustic Rating
Is this possible?
Thank you,
1 REPLY 1
We've developed our own label tag which uses properties and expressions to pull in the data and show in the order we want.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.2.2 | Archicad 28 Apple Silicon
macOS Sequoia (15)
