Door in Curtain Wall
Goodmorning AC users!
I've been exprerimenting with curtain walls and doors.
I try to create a door and I cannot figure out how to properly delete the bottom horizontal divider (?) and have the dividers next to it extend to the door.
The attachment will probably help you understand more than my description.
Cheers
14 Replies 14
Eduardo Rolon
Door elevation is because of the thickness of the "invisible frame" change it to 0 and it should go down.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
It is 0
Eduardo Rolon
AC29 US/INT -> AC08
No need to make the frame invisible.
Just make sure the frame height/width is zero and the and the panel slot is also zero.
Hey Barry, thank you for the tip,
it worked!
Cheers!
