cadsph
Door not showing in plan
I've inserted a door, but it's not showing in plan view, but I can see it in section.
please see attached.
I've checked the layers - but I'm not sure if it's a setting in window elements?
1 Solution
Miha_M
Take a look into Model View Options, you may have "show opening only" activated for your saved ground floor view. The exclamation mark in your section title indicates that it doesn't show the assigned view settings.
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Go to post
4 Replies 4
Miha_M
| Archicad 4.5 - 29
cadsph
Thanks Miha
Legolegend
Or it could be the wall that the door is in.  If you have the floor plan display option of the wall set to 'Outline only' then change it to 'Projected'
Legolegend
