‎2008-04-08
08:12 PM
‎2024-06-03
11:29 AM
Aruzhan Ilaikova
‎2008-04-08 09:17 PM
‎2008-04-09 01:20 PM
‎2008-04-09 01:28 PM
‎2008-04-09 03:23 PM
How would you like to become my mentor?..Sure, my going rate is measured in biscuits per hour. I'm sure we could come to an arrangement!
it won't select the wall that i want to when trying to put in a door? instead it selects the exterior wall at FFL..!!If there are several walls on the same point as you are trying to place your door, after the first click to select your base point, move your mouse to visually indicate which wall you want to place it in. You will see a blank opening on plan flicking between the different walls. Click again to select the correct one.
‎2008-04-09 03:29 PM
