2008-04-06
01:35 PM
- last edited on
2024-06-03
11:33 AM
by
Aruzhan Hamar
2008-04-06 02:17 PM
AAJS wrote:AAJS:
I started with ITG and tried to create a slab but it won't let me change the thickness which is set as a default and greyed out. How can i change this?
AAJS wrote:One approach is to use the x and y inputs to key in the dimensions with the slab tool to accurately draw the footprint of the building, then you can magic wand the edge of the slab with the wall tool selected to add the exterior walls. If you already have the box then you can use the Marquee tool to stretch the rear corner of the building to its correct location.
Also the building is a rectangular shaped with reduced width for the rear section. What would be the best way to draw this? If i draw it as a rectangular shaped wall construction (a box) then how can i move the rear walls so that the width at this point is less than the front part of the building.
2008-04-06 02:33 PM
2008-04-06 03:01 PM
