Doors and Windows don't show in Plan
Chris Beebe
I'm in r15, and some doors and windows don't show in plan but do in 3D. This used to be an easy setting in previous releases, but for the life of me, I can't get them to show. Story setting is 92'. Bottom of Wall and Door is 95'-8". I've adjusted the Story Setting to 95'-8", 95'-0", and played with Wall Settings (Projected, Projected with Overhead, Cut). The wall showes, but not the door.
Please advise. Much appreciated!
Chris
Thank You,
Chris Beebe
Brad Elliott
Chris,
Check your model view options in the document window. Make sure the door options has show on plan turned on.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Chris
Also check your renovation status!
David Maudlin
Chris:
Also check for the Doors & Windows: Door Settings > Floor Plan & Section > Floor Plan Display > Floor Plan Display : Symbolic.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
