Read more
Drawing beams in a sloping glass roof?
I am trying to draw a roof made of glass in a conservatory how do I do the aluminium support beams for the glass as they slope down to the glass walls. I have tried doing beams using the beam tool but you cannot angle these. Help please./Jane iMac
8 REPLIES 8
Stig Bengtsson
Yes, you can slope the beams.
Stig
Architect AIA RIBA SAR/MSA, Graphisoft Registered Consultant
AC19 SWE 7006
AC20 SWE 4012
maybe as I am using Start Edition of ArchiCad this is not possible??
Srinivas
Here's how you can slope beams.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Interesting that option to give the the angle is not possible in my ArchiCad edition.
Srinivas
Although I never worked on the start edition, I thought this is a standard feature and should be available. Can you add your archicad version in your signature like the rest of others, so that others can help you here.
ArchiCAD Services
iMac, Windows 10
Thanks for the tip I am new to adding posts.
Interior and Landscape Architect
ArchiCad Start Edition on iMac
If you're using a roof element to create the sloping glass, use a roof to create the glazing bars too, same slope but thicker, and drop them down 10mm (or half an inch).
Also with regard to signature, click on the Profile button under the Graphisoft banner at the top of the forum page, enter your details in the box near the bottom of the form, and it will show up after every post you make.
Thanks all for your comments very useful. /Jane
