2005-07-25 11:13 PM - last edited on 2023-05-23 03:34 PM by Rubia Torres
2005-07-25 11:14 PM
2005-07-25 11:15 PM
2005-07-26 01:22 AM
2005-07-26 01:42 AM
2005-07-26 02:05 AM
"Link" wrote:
From a quick glance it looks like you could benefit from Solid Element Operations on those roofs.
I could not get the two roofs in the upper right to intersect. I probably need more training with the Solid Element Operations tool. How would you go about getting these two roofs to intersect?
Also keep in mind that for the most part (like walls) roofs with the same fills will heal in section. Same with slabs.
One would think so. Both of the blue roofs in the upper right are built using the same composite which of course has identical fills. I wonder why the two roofs with the same composite are not healing in section?
quote]
Thanks,
John
2005-07-26 02:16 AM
2005-07-26 04:31 AM
2005-07-26 05:02 AM
