Learn more
Drawing composites
I am drawing some cabins made of wood, that consists in the following layers,
wooden boards
horizontal wood ribbons every 60cm placed in a vertical layout
vertical wood ribbons every 60 cm placed in horizontal layout
My question is if I can create a composite which one of its layers will be formed by the horizontal or vertical ribbons(beams or pillars in archicad) placed in vertical or horizontal layout arrangement.
2 Replies 2
Composite walls will only create skins (layers) in a wall that are solid in 3D (they can be a transparent building material for cavities) and these skins will appear as a fill in plan and section.
It is not possible to create the actual timber components that form the skin.
A complex profile wall will allow you to create the horizontal components, but there is no way to do the vertical components in a complex profile.
You would need a 'wall accessory' (and the wall accessory add-on) to do the vertical timbers if you want them linked to the wall.
There is a post here somewhere that has an option to do custom profiles for a wall cladding that may help - I will see if I can find it.
This is the post I was thinking of.
not sure if it will help.
You may need a combination of a complex profile wall with the horizontal members and this accessory for the vertical.
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=58432&p=274740#p274740
