2012-02-07 09:50 PM - last edited on 2023-05-24 12:59 PM by Rubia Torres
2012-02-07 09:58 PM
2012-02-07 10:41 PM
2012-02-07 10:58 PM
2012-02-07 11:17 PM
tfulmer wrote:You can create each shape (looking at it in elevation) as a complex profile and extrude it as a wall or beam.
I wish I could just draw on the face of the wall and make some kind of extrusion.
2012-02-07 11:17 PM
2012-02-07 11:21 PM
tfulmer wrote:When u use the Library Manger to insert objects it doesnt matter where u are (as long as u are in archicad ). When u created the object it saved also the main floor plan view which was the view as shown in the print screen - as it will appear in floor plan, so u insert it in floor plan and place it outside the wall, then it will appear in elevation and 3d like normal objects from the libray.
Thank you for your help. I went in and made a sample shape to see if I could get through the steps you mentioned. I made the shape and now if you could just help me know where to insert it. Do I insert the object in plan view or an elevation or the generic perspective?
2012-02-07 11:22 PM
2012-02-08 03:58 AM
2012-02-08 09:14 AM
