2009-05-13 08:03 PM
2009-05-13 08:47 PM
2009-05-16 06:23 PM
Dwight wrote:And a Solid Element Operation subtraction, with a gull-shaped slanted profiled column, for carving the end conditions.
A Complex Profile used in a circular wall gets you most of the way.
Complex Profiles.
2009-05-17 08:55 PM
2009-05-18 05:56 PM
dash_medo wrote:Take a look at OBJECTiVE as a solution to this problem - an example image is attached. I did the following:
is it possible to design something similar to Nicholas Grimshaw's national space center with ArchiCAD?? My concern is how can i design the cushion and the structure with ArchiCAD??
2009-05-18 08:06 PM
2009-05-18 08:41 PM
Dwight wrote:Well this is an embossed-ashlar-looking ETFE cushion proof-of-concept[-and-limitations].
Iggy: Can you show me that?
2009-05-19 12:00 AM
lec1212 wrote:I'll respond with a cautious "yes", although it comes down to the specific detailing required. I've attached one example with a curved end. Is this what you had in mind?
Ralph wrote;
"4) Used OBJECTiVE's Split tool to chamfer the ends of the horizontal ribs."
Question:
Could you have radius'ed the ends instead, if you had wanted to?
2009-05-19 02:40 AM
2009-05-19 11:02 AM
lec1212 wrote:1. Yes, all the objects were created with OBJECTiVE's toolset and required no additional GDL scripting. I don't believe GDL is a practical solution for the vast majority of ArchiCAD users.
I assume that is done with provided tools of Objective and did not require additional gdl programing?
Curious, do you mind; why is that a qualified yes?
And, can two of more objects created with Objective, be combined as one
in either Objective or AC's "Save selection as"(.gsm)?
