‎2017-08-25
12:42 AM
‎2023-05-23
06:04 PM
Rubia Torres
‎2017-08-25 02:57 AM
R wrote:The MORPH tool has a polyline mode which shows in 3D.
Does ArchiCAD have a way to actually create a 3D polyline? If I knew how to do this, maybe I could just put the rail on the polyline and not need to set elevations for lots of points.
‎2017-08-27 12:43 AM
R wrote:In Edit Mode, make "Segments and Nodes" visible. If you then select the Railing Reference Surface you will see that the Railing Reference Line is also displayed and those Railing Nodes will be located on the Railing Reference Line. This way it will be easier to find them.
First problem: how to select a rail node in edit mode. I just fuss around until I finally get it. Sometimes it works, most of the time it doesn't. I have no idea what I'm doing differently when I succeed. The documentation doesn't seem to have anything about this- it just makes it sound easy.
