Edit Profile of Selection?
It must be right in front of me.
I want to select a profile wall, and have a direct command to open its profile in the profile manager. Not Capture Profile, that makes a new 'custom' profile from the selection. Not selecting from the list and then Edit Chosen Profile.
It's got to be in the info box, context menu, and/or profile manager, but I don't see it anywhere.
If I want to open an object, I just select it and Open Object.
On the other hand, you can't get at a composite via selection.
But if you Opt-click on the wall, that composite will be active when you go to Composites.
Seems like I should be able to get right to that profile somehow.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
0 REPLIES 0
