2012-12-05
01:30 AM
2023-05-24
12:51 PM
Rubia Torres
2012-12-05 01:55 AM
2012-12-05 05:10 AM
2012-12-05 06:43 AM
2012-12-05 06:52 AM
2012-12-05 06:55 AM
Geof wrote:Are you by chance using a Work Environment from an old version of Archicad?
Hmm -- all I see is Modify Curtain Wall and Modify Morph. I don't even see it in Work Environment > Menus > List All Commands in Alphabetical Order or List All Menus in Alphabetical Order.
2012-12-05 07:14 AM
2012-12-05 08:22 AM
Geof wrote:Yes if you select your custom profile and then press the EDIT button.
That must be it -- thanks. Can I change the Command Layout Scheme to the standard AC16 without affecting my custom Shortcut, Tool, or Palette Schemes?
