Edit > Modify Wall?
Geof Gainer
I seem to have missed where Edit > Modify Wall went in recent versions. I can't find it in Work Environment Menu settings either. Did it become something else?
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
7 REPLIES 7
Try the DESIGN menu > Modify Wall.
...and, since you're on a Mac running 10.6 or higher ... just type "Modify" in the search box in the Help menu... and the command will show up, if it is in your Work Environment... hovering over it there will actually make the menus unfold to show you where it is, or just click it in the search results.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Geof Gainer
Hmm -- all I see is Modify Curtain Wall and Modify Morph. I don't even see it in Work Environment > Menus > List All Commands in Alphabetical Order or List All Menus in Alphabetical Order.
David Collins
Design/ Wall Extras/ Structure, Reference Line, Invert direction ?
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
Are you by chance using a Work Environment from an old version of Archicad?
This won't show the new commands even in the "Show all commands".
You will need to list "All new commands".
Or set the standard WE for the version you are using.
Geof Gainer
That must be it -- thanks. Can I change the Command Layout Scheme to the standard AC16 without affecting my custom Shortcut, Tool, or Palette Schemes?
Yes if you select your custom profile and then press the EDIT button.
Then you can choose the various individual schemes - you can mix and match from any that have been saved so you can keep your shortcuts but use the Standard 16 commands.
