2024-01-05 04:51 PM
Hi all, Is there any way to edit multiply text labels on drawing?
For example if I have around 25 sheets with different metalwork types and a label saying "Architectural Metalwork. To be PCC to RAL 3015" on every sheet, and at some point the actual RAL changes, is there any way to edit all of these labels across all the sheets in one go instead of going through every sheet and edit them manually?
Autotext perhaps?
Thanks
Solved! Go to Solution.
2024-01-05 10:43 PM
2024-01-05 10:43 PM
2024-01-06 07:30 PM
The "standard" workflow is to use or create a property that will have the information, ie "RAL Finish…"
OTOH if you are placing "dumb" text labels then @Turit suggestion is the solution.
another Moderator
