Editing a mesh
I am happy with the mesh tool of archicad. I would like to ask if there is a way that I can edit the height of several points at a time or unless editing one by one but not having to press the "z" icon again in the tools palette once I changed the coordinate in a point.
If the nodes are all on the same ridge you can tick the "Apply to all" check box and all nodes on that ridge will change.
Otherwise you can only change one node at a time.
The pet palette should remember the last operation (i.e. z height) used - so long as you don't press cancel.
