ā2006-09-29 02:46 PM
ā2006-09-29 03:06 PM
Mats_Knutsson wrote:Probably because element ID varies wildly among different instances, depending on what you are using it for.
Why is the default setting to exlude ID for all elements in the favorite preferences?
ā2006-09-29 03:19 PM
TomWaltz wrote:Thanks guru,Mats_Knutsson wrote:Probably because element ID varies wildly among different instances, depending on what you are using it for.
Doors, for example, might all be the same door but have IDs like 101A. 102A, 105B, etc.
Windows might be labeled TYPE A, TYPE B, TYPE C, etc.
I think it was probably a 50/50 split and they erred on the "safe" side. I do like that you can make ID part of some favorites and not others (even though I'm not a big favorites user)
