This issue/potential bug started in a TW2 project and continued after I saved as a PLN file during troubleshooting.
For this project, we used the curtain wall tool to design many variations of storefront windows. Each various storefront "window" has an unique ID (SF-1, SF-2,...) for scheduling purposes. To keep the model intelligent, I have labeled each storefront curtain wall/window by checking Label Elements in the which shows the ID in elevations.
At some point after placing elevation views onto our layout sheets, the element label had shifted to the right. If I open the elevation view, it will show the label in the correct position. I have tried everything I could think of - replacing the drawing view on layout sheet, toggling between auto and manual update, deleting the label and re-labeling, and even placing a new elevation.
I have attached an image showing the source elevation view with label in correct position next to the linked layout sheet view showing the label in the incorrect position. This issue occurs in other select elevation views as well and has been noticed at different random times.
Is this a bug? Has anyone else experienced this issue? I will hope for a work-around or solution before I replace all the labels with dumb 2D text. Thanks!
