Window in elevation
Hi, I have problem with window which is not shown corectly in elevation, like I cant see complite frame around my window, I dont know why it is that.
4 Replies 4
Hi aaaatrums,
I would guess the line partially disappears because the external face of the frame is flush with the wall face, and there is no gap between the edge of the window and the wall.
To solve the problem either increase the window reveal to set the window slightly further back, or adjust the frame settings to give a gap around the edge of the frame.
If you are still having problems please post a screenshot of the frame settings.
Hope that helps!
Is the window frame material the same as the wall material? If so, make them different (if necessary make a duplicate of the material with the same settings, different name)
Yes different material helps, thanks
It helps but it shouldn't really be necessary. Is it a standard AC window? Do others do it?
