‎2006-05-16 02:33 PM
‎2006-05-16 03:24 PM
Jesikuh123 wrote:See also : Installation / New user : Modeling Vs. Drafting
So I am working on elevations, and I am wondering if there is a way that I can use the 3d model rebuild mode and still show the below grade stuff as dashed etc.
I find that if I change the elevation to a drawing I can go ahead and change line wights, and types to show as they are supposed to , and use partial hatching which I learned how to do through you guys, thank you.
The thing is hough that when I do this if the building or model changes a little bit the elevations are not updated. Also, if I go ahead and update my drawing then I lose most of my changes that I made in elevation.
Does any one know a better way to do this? Or is this just how it is done?
Thank You
Jess
‎2006-05-16 03:35 PM
‎2006-05-16 04:29 PM
‎2006-05-16 05:01 PM
RobertNichols wrote:To make sure I understand, what you are suggesting will just cover up the model so you dont see it, correct? And then I am just 2D drawing over it?
I recently came up with a solution for this that pleases me to no end. This, after struggling with the problem for years.
Create a vector fill made up of diagonal lines. Then create a pen that is a really fat white line.
In your section window, still attached to the model, snap vertices to place a fill covering the area below grade. Turn the fill's outline off, and set the fill pen to fat white, make sure the fill is "on top" of the modeled information, and you will be very happy.
‎2006-05-16 06:20 PM
‎2006-05-16 06:24 PM
RobertNichols wrote:We've been doing this for some time and found that it's a good idea to extend the mask a good bit beyond the actual building on each side in case it grows.
That's correct. The model is still a dynamic 3d thing, and you are simply putting a 2d mask over it.
The pattern of the mask (diagonal lines) makes the modeled lines behind appear dashed. All your changes to the model come through with no fuss, unless you change your ground line, then you get to tweak the fill coverage.
‎2006-05-16 11:48 PM
‎2006-05-17 07:18 AM
