Elevations only show as a marker head in version 18
In all previous versions, the elevation marker showed as a marker head and a line. In version 18, there is only a marker head. In contrast, a section line still shows the marker head and the line.
I hope that explanation makes sense.
How do I get the elevation line to show up?
Thanks!
Arch
2 Replies 2
Stress Co_
Turn on "Marker Range"
View> On Screen View Options> Marker Range
Marc Corney, Architect
Red Canoe Architecture, P. A.
NCornia
Graphisoft Alumni
Graphisoft Alumni
We changed this default setting in the AC18 USA version because it was confusing to many new users what these lines actually were. Notice if you select a marker the lines will be highlighted and you can see the extents of the elevation.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
