Elliptical Staircase
Hello!
I have 2 questions that i would appreciate very much if someone could help me with:
1) Why archicad doesn't let us make an elliptical stair with more than 360º? Even if i type in the total height and stairs, when i'm drawing it stops at 360º and doesn't let me finish it.
2) As the attached picture shows, i can't seem to get rid of that hatch in section. Why is that? I supose it is due to the fact it is an elliptical stair and since it is a curved surface, archicad have those lines to "show" it. But i wish i could just turn it off.
Thank you in advance!
1. Unfortunately, this is a limitation that Stairs cannot overlap themselves, this is why you cannot make it cover more than 360 degrees.
2. I am sorry, I do not have any suggestions how you could get rid of those lines. One workaround would be to cover them with Fills.
Ok, thank you so much for your help!
Hmooslechner
Maybe something similar is possible:
There is a GDL-Command can make spirals without inner lines in views..
i messed around with it - its not perfect but usable so far..
the stringers:
https://www.youtube.com/watch?v=xw1FG6a7ZiM
the stair itself:
AC23eduAut:
https://www.dropbox.com/s/b6ef7pk423gd9lo/Ellipsenstiege.pln?dl=0
