Elliptical Staircase
Hello!
I have 2 questions that i would appreciate very much if someone could help me with:
1) Why archicad doesn't let us make an elliptical stair with more than 360º? Even if i type in the total height and stairs, when i'm drawing it stops at 360º and doesn't let me finish it.
2) As the attached picture shows, i can't seem to get rid of that hatch in section. Why is that? I supose it is due to the fact it is an elliptical stair and since it is a curved surface, archicad have those lines to "show" it. But i wish i could just turn it off.
Thank you in advance!
1 Solution
1. Unfortunately, this is a limitation that Stairs cannot overlap themselves, this is why you cannot make it cover more than 360 degrees.
2. I am sorry, I do not have any suggestions how you could get rid of those lines. One workaround would be to cover them with Fills.
Go to post
3 Replies 3
Ok, thank you so much for your help!
Hmooslechner
Maybe something similar is possible:
There is a GDL-Command can make spirals without inner lines in views..
i messed around with it - its not perfect but usable so far..
the stringers:
https://www.youtube.com/watch?v=xw1FG6a7ZiM
the stair itself:
AC23eduAut:
https://www.dropbox.com/s/b6ef7pk423gd9lo/Ellipsenstiege.pln?dl=0
