‎2004-12-07
08:28 PM
‎2023-05-23
05:24 PM
Rubia Torres
‎2004-12-08 07:13 AM
‎2004-12-08 09:35 AM
‎2004-12-08 03:22 PM
‎2004-12-08 04:37 PM
Reinhold wrote:
As a work around we use the empty window object with a zero sill height, in some cases, to be able to list windows & set custom listing texts on plan. We us this method to get a correct look in plan as well as elevation. Anyway, in AC 9.0 this is no longer possible.
Eventhough the sill height is set to Zero i get lines showing the wall thickness on plan. I know that windows & doors use the Cover fill function, but how do i get rid of the lines?
‎2004-12-08 05:17 PM
I'm not sure why you want to do what you are doing but does this answer your question?
In the Windows Selection Settings dialogue box go to Parameters/2D Representation/Use Fills and set it to OFF.
In your plan view, select the empty opening and set the Door/Window Floor Plan Contours button as shown below. (red arrow)
‎2004-12-08 06:10 PM
Reinhold wrote:
Ive tried that one. Sorry, it doent help. Its the lines showing the wall thickness i need to get rid of & not window width lines.
I think this is a BUG!!
‎2004-12-09 04:09 PM
‎2005-10-18 06:56 PM
