Although Iāve been using archicad for 4 years. There is a little pesky problem Iāve encountered many times through the years.
Itās trying to make the union of a wall and slab (or beam) look monolithical (making the joining of these two surfaces disappear).
Iāve tried many work arounds- Extending the walls past the slab, covering the joint lines with white fills, Erasing the joint of an unlinked sections, Using the excellent hollow box library part from David Nicholson.
Have I missed something or thereās a better way?
My way of working is to try to maintain the sections/ elevations linked as long as possible. Sometimes clients need hidden lines 3d drawings, erasing the joint lines in these cases is a pain in the neck.
Any help will be appreciated.
