Error Message: Cannot Find Library Parts or Internal Macros
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-05-07 01:54 AM
‎2005-05-07
01:54 AM
These will not be included in the Archive.
Why is this message being generated? Do I need to worry about it or do something differently?
Under Options for the Archive I've selected all four checkboxes.
Thank you,
John
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-07 01:59 AM
‎2005-05-07
01:59 AM
After I select Save Anyway a report is generated. I've attached an image of the report. What does this mean? Where would I find the parts and images that the report is refering to?
Thank you,
John
Thank you,
John
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-08 06:28 PM
‎2005-05-08
06:28 PM
AC archive have problems with macros from some previous versions. In my practice I resolve this problem with saving options - add all loaded library. This option add all macros, but problem is capacity of flies.
Regards
Paweł
Regards
Paweł
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-09 01:58 AM
‎2005-05-09
01:58 AM
An object in your library has a referred macro part but your parameter setting may not actually be refering to it. i am guessing you have called up a standard object. The trouble is the macros are usually stored in a different folder called something like Macros (or DW macros if the object is a door or window.)
Easiest solution is to include the whole macro folder in your library. It is usually fairly small.
Cheers John
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-09 08:55 AM
‎2005-05-09
08:55 AM
John,
This time it doesn't look like a missing macro, but a missing library part.
It looks like some one has created a library part called "Test.gsm". The library part is missing or residing some where that you do not have access to. ArchiCAD was also unable to find the two bitmap images included in the "Test.gsm"
HTH.
Cheers.
Ben
HTH.
Cheers.
Ben
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-11 09:31 AM
‎2005-05-11
09:31 AM
Hi guys,
AC archive have problems with macros from some previous versions.it was the AC 6.5 that had a problem with including macros when saving as an Archive.
