Export Image of Composite
Is there any way to export the image of a composite?
I've many times used screenshots, but now the composite is so big that it goes outside my screen area.
Is there some way to print it out in some way?
15 Replies 15
You mean you have to manually add the annotations, descriptions and arrows to all the layers of the composite? Then it's not a solution, cause I would spend weeks doing that. It's not possible to have it do that automatically? I mean, all the data is in the model.
I have not heard anything back from you.
insideru
If a labeled object will do, have you tried creating a wall or whatever your composite is and adding a skins label to it?
ARCHICAD 28 INT
macOS Sequoia
Not sure what you mean, cause I don't have time to add labels manually of the numerous wall composites I have, with numerous materials.
insideru
I was talking about the skin list label. You just click an object and it automatically labels all skins and their respective thickness.
ARCHICAD 28 INT
macOS Sequoia
insideru
You could try to schedule a components list like this, see if you like it. You could add a 2d plan preview as well, but i don't see a way to make it appear only once and bigger, so it will appear on each skin's row. Make sure you check merge uniform items.
ARCHICAD 28 INT
macOS Sequoia
