hello all
Please help me with this..
for some reason the ctrl+Alt for syringe and Alt for eyedropper is not working on my pc..because of which i am not able to match properties....
I have changed the CPU recently and the problem still persist...
If you have another object selected nothing will appear to happen: e.g. if you have a slab selected on screen and Alt-Click on a window, nothing will change on screen. You need to de-select the slab first in order for the Window tool to be activated.
hmm that doesnt seem to be a problem...i make sure everytime..to start with, line to line...doesnt work
besides i can use this syringe and eyedrop command in other computer and it works good...so based on that i am not doubting my understanding of the tool...
thanks bruce for trying
something as simple as a line doesnt transfer the parameters to another.
eyedropper-appears when picking up parameters from an element as part of Parameter Transfer shortcut
syringe-appears when transferring parameters of one element to another as part of Parameter Transfer shortcut
but then there is no honk or no parameters are transfered
I know i am doing nothing wrong while using the command as i am able to do it on the rest of the computers in the office.
