FIX AC RATHER THAN CERTIFICATION
May I respectfully suggest to GS that they fix the issues with Archicad rather than spending their time on certification.
The latest build version crashes my computer about 5 times per day. Who knows why?
In some circumstances, a simple task such as the following causes the computer to hang.
Select text.
Click "b" to change the text angle. Before hitting enter, Click "b" again to change the angle. Computer hangs.
There are so many workarounds and issues with AC, I would much rather GS spend their time fixing and adding enhancements rather than spending time on certification.
Grant
3 Replies 3
Select text.
Grant
???? Which lastest build? AC9? I certainly have not experienced these kind of crashes. If I did I would be screaming to my reseller (Right Steve?)
Anyway, I cannot replicate your computer freeze as I have different shortcut keys. Which Work Environment profile do you use? Also, I cannot get it to freeze using my rotate shortcut key.
The 2018 build recently released. I can duplicate this problem all the time.
Yes, I use a customized work environment but didn't have these problems in the previous build.
Grant
TomWaltz
Have you submitted a bug report for this yet?
Tom Waltz
