FROZEN VIEW
EL ARCHIVO QUE ESTUVE TRABAJANDO SE CONGELO EN UNA VISTA, NO SE PUEDE MANEJAR EL ZOOM, LO MISMO EN LAS VISTAS DE CORTES ELEVACIONES Y LAMINAS, TODOS LOS MENUS ESTAN ACTIVOS, PERO SE NO PUEDE MANIPULAR EL ZOOM.
I am working with archicad 14..
the project i've been working on, froze on a view and I can't zoom in or out.
same happens in seccion, elevation and layout windows..
all menus are active, however the zoom tool is not working
closing and reopening the project is no use.. it opens up in the same frozen view..
it must be an archicad 14 bug becuase i've never experienced this problem before..
3 Replies 3
Eduardo Rolon
Si abres un proyecto nuevo y sucede los mismo es posible que sean los drivers del mouse. Puedes tratar usando el zoom dando click en los iconos de la pantalla a ver.
If you open a new project and get the same error then it might be the mouse drivers. Try using a keyboard shortcut or clicking on the zoom button in the drawing window. AFAIK this has not come up before and it might be a system issue.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Mouse driver are fine..
Besides, when I zoom in, the sidebars get bigger, meaning that the zooming is actually working.. but the project view doesnt change at all..
Eduardo Rolon
Did you try a new file?
Might need to reinstall AC.
AC29 US/INT -> AC08
