Srinivas
Fascia Modeling Problem
Hi all,
I need a bit of help here, having problem modeling one of the fascia element that goes under a curved roof (which is a complex profile) please see attached sketch. Currently on v15, any help is grealy appreciated.
Thanks in advance.
-Srinivas.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
5 Replies 5
Erich
Srinivas,
You could do this as an object. Use a complex profiled wall. Draw in plan to the elevation curve, then turn it into an object with the side view up.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
I wonder if the following article gives you any ideas for the solution:
http://www.archicadwiki.com/GableProfileWithShell
Srinivas
Hi Erich,
Did the same, and save the wall in plan view then I am trying to add the ROTZ command in the GDL script no luck yet, will try again in the morning at let you know.
Thanks.
ArchiCAD Service
Mac, Windows 11
Srinivas
Thanks Laszlo, the rake is actually a curved one unlike the straight one in the sample, not an expert with shell here, but I will give it a shot. thank you.
ArchiCAD Service
Mac, Windows 11
Erich
Srivnas,
If getting the rotation is proving difficult, just set your correct view prior to making the object. The rotation will then get added to the object by ArchiCAD.
So, assuming you normally would make the object with a top down view. Use a side view instead.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
