Fascia Modeling Problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2013-03-11
06:23 PM
- last edited on
2023-05-23
02:37 PM
by
Rubia Torres
2013-03-11
06:23 PM
I need a bit of help here, having problem modeling one of the fascia element that goes under a curved roof (which is a complex profile) please see attached sketch. Currently on v15, any help is grealy appreciated.
Thanks in advance.
-Srinivas.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
ArchiCAD Service
Mac, Windows 11
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-03-11 08:34 PM
2013-03-11
08:34 PM
Srinivas,
You could do this as an object. Use a complex profiled wall. Draw in plan to the elevation curve, then turn it into an object with the side view up.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-03-11 08:35 PM
2013-03-11
08:35 PM
I wonder if the following article gives you any ideas for the solution:
http://www.archicadwiki.com/GableProfileWithShell
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-03-11 08:36 PM
2013-03-11
08:36 PM
Hi Erich,
Did the same, and save the wall in plan view then I am trying to add the ROTZ command in the GDL script no luck yet, will try again in the morning at let you know.
Thanks.
Thanks.
ArchiCAD Service
Mac, Windows 11
ArchiCAD Service
Mac, Windows 11
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-03-11 08:38 PM
2013-03-11
08:38 PM
Thanks Laszlo, the rake is actually a curved one unlike the straight one in the sample, not an expert with shell here, but I will give it a shot. thank you.
ArchiCAD Service
Mac, Windows 11
ArchiCAD Service
Mac, Windows 11
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-03-11 08:41 PM
2013-03-11
08:41 PM
Srivnas,
If getting the rotation is proving difficult, just set your correct view prior to making the object. The rotation will then get added to the object by ArchiCAD.
So, assuming you normally would make the object with a top down view. Use a side view instead.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
