Favorite Palette
Llian
I don't seem to be able to reduce the width of the palette without losing the names. This is the smallest width. Can anyone help?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Llian
After the update 8005, the issue seems to have resolved. I can now reduced the width without losing the description. 🙂
5 REPLIES 5
Have you tried adjusting the column width marker?
I don't seem to have this in the Windows version so I don't know if it can be adjusted or not (or even why it would be there).
Rick Thompson
I have the same issue with 20. The last update was said to fix it, but not for me. The column adjuster doesn't work, best I can tell. The odd thing is it was fine after migrating from 19, but started acting up after I did a re-install trying to fix something unrelated. I had to switch to icons, which I don't really like.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Erwin Edel
No real fix for the problem at hand, but have you tried using the 'popup' favourites from the toolbox icons/buttons? You can change these to list / 3D preview as preferred and you don't have another palette cluttering your workspace.
You can also get to the favourites fairly easily from the settings dialogue of all the tools.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Llian
Thanks everyone. I can reduce if switch to the medium thumbnail view….oh well! it's about adapting to change.
Llian
