Feature Request - Openings in Shell
ShaunTaylor
Apologies if this has already been asked for, I couldn't find a similar post.
I noticed that we could cut openings in the Roof Tool. Firstly, great feature. Can I make a wish for the Openings tool to be able to be used on a Shell?
I do understand that I can cut a hole in my shell. But using an opening would simplify the workflow and training around cutting holes through your main tools.
Particularly when dealing with penetrations. In some situations, you may have a Shell in Lieu of a Slab, where the Roof Tool just isn't appropriate for the situation. It would be great to be able to use the same workflow (openings) for your penetration regardless of using a Slab, Roof or Shell for your Floor, Wall or Roof structure.
Shaun.
0 REPLIES 0
Setup info provided by author
