Fill Scale
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-07-27 11:57 PM
‎2011-07-27
11:57 PM
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC28 USA | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-28 12:16 AM
‎2011-07-28
12:16 AM
You can use the 'Distorted Fill' construction method handles on the fill tool and resize the scale of the fill pattern with them. Change the length of each handle equally to keep from skewing the pattern. It's not a perfect solution, but it works.
AC 6-27 - Intel i9-9900K - RTX3090 - Windows 11 - 64GB RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-28 12:21 AM
‎2011-07-28
12:21 AM
Thanks...will try it out later..
Meanwhile, I am just wondering what is the reasoning for not having a scale factor in the fill tool?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-28 03:53 AM
‎2011-07-28
03:53 AM
When you create the fill you have a choice of making it either a fixed printer size (regardless of the scale it will always print at the same spacing on paper) or scaled so that it adjusts with your scale and will always appear to be the same dimensional spacing (great for when you want to represent the actual size of a hatched element like 200x200 tiling).
You can either creat new fills as the needs arise or edit the existing fills but be aware all instances of that fill will be affected.
Or if you want to adjust just the odd fill here or there you can use the distorted fill handles that MMontgomery mentioned.
A handle that is 1000mm long (1 metre) will be one unit size of your fill hatch spacing.
Stretch the handle to 2 metres and the spacing will be twice as big.
I'm not sure what the unit size will be for those of you using Imperial measurements.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-28 02:07 PM
‎2011-07-28
02:07 PM
Barry wrote:The ever useful 3'-3 3/8". Also shows up in the Parallel Projection Settings dialog box.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
