Fill types in independent details - workflow question
In residential typical wall sections, I noticed that the default fill for the 2x4 stud wall does not have a "drafting fill" associated with it. When you manually change an independent detail's cut fill to drafting fill, it defaults over to a 100% fill, whereas the built-in cut and cover fills are set to 0%.
I assume this is a workflow issue. My question is what workflow uses that feature and when would I want to incorporate it in my work?
Snap
This seems more buglike than featurish. (If I understand you correctly.) I don't see any advantage to it.
Well, I was trying to see it in a positive light.
Snap
