Fillet morph
I am trying to fillet two edges of a morph that merge into a corner. I can only fillet one of the edges if I try to fillet the other a pop up dialogue says, radio too large... you can fillet the edge.
Any answers?
4 Replies 4
DGSketcher
Legend
See if this helps...
https://helpcenter.graphisoft.com/guides/archicad-22/archicad-22-reference-guide/elements-of-the-vir...
You must select both edges at the same time, then fillet and apply to all edges.
How can I select both edges at the same time. It seems imposible to me.
The same as you do for other elements, by holding the SHIFT key to add or subtract from your selection set.
But because you are talking about individual edges of a morph, you must make sure that the selection tool is in sub-element mode.
Or use CTRL+SHIFT to temporarily enter sub-element selection mode.
The CTRL key toggles this mode on while you hold it.
