Fills not scaling correctly
The fills in my project were all correctly scaled yesterday but today I am finding that they have scaled themselves so that the patterns are tiny. I can't understand what has happened. i tried 'scale independent' and 'scale with plan' and also changing the attributes to larger scales and nothing seems to work.
I'd love some advice, thanks.
4 REPLIES 4
What version archicad are you on? It could be a bit map display of the fills versus vectorial hatching. Check your display or model view options depending on your archicad version.
Thank you for the reply,
there is a little bitmap image I had never noticed before on the element attributes dialogue box(or whatever it's called!). It's archiCad 10 by the way. I'll try what you sugested, thanks.
Thanks! It was in View> on screen view options> vectorial hatching. I just had to click on 'vectorial hatching' and that sorted it out.
Djordje
Make sure to save your views. The view options are saved with the view.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
