‎2005-03-16 01:01 AM
‎2005-03-16 11:05 AM
‎2005-03-18 05:55 PM
JR wrote:First make sure that the fill is correctly sized. Then set the fills to Vectorial. In your saved view, and in PlotMaker. If you are mixing Vectorial and Bitmap fills, then make sure to set the Plotmaker fill display to Original settings.
I have a brick fill of 400x200 bricks that prints out with plotmaker at about half that size. What do I have to do to print a correct scale?
