Fills print to wrong size
I have a brick fill of 400x200 bricks that prints out with plotmaker at about half that size. What do I have to do to print a correct scale?
Ben Odonnell
JR,
Make sure that your display options in plotmaker are sett correctly. I am assuming that they are set to bitmap at the moment, you'll need to change it to vectorial so plotmaker can print the right thing.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
First make sure that the fill is correctly sized. Then set the fills to Vectorial. In your saved view, and in PlotMaker. If you are mixing Vectorial and Bitmap fills, then make sure to set the Plotmaker fill display to Original settings.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
