Luisa8
Find an undesired material in the model
Hello everyone, I generated a list of load-bearing exterior walls in Archicad 26. Initially, I used autoclaved aerated concrete as the material, and then switched to limestone blocks. In the list, there is a position with the old material autoclaved aerated concrete, with a length of one millimeter. For the subsequent analysis with the model, it would still be helpful to update this material. Is there a way for me to filter and locate this material in the model?
Eduardo Rolon
As written this does not make sense and I think it is a spam post, but the answer is yes and the solution is to either use "Find and Select" or the "list" that you mention which is actually a "Schedule" use the "Show Selection" button.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
