Finding/Importing Laboratory-Specific CAD Objects
ml78
I am very new to Archicad.  I will be using this program to design clinical laboratory spaces.  Can someone direct me on how to find 3d CAD images of laboratory equipment and objects?
4 REPLIES 4
Ricardo Lopez
Hi. You can check that type of 3D assets in webpages like: bimobject3dwarehouse , etc. and depending on the file format available (rfa, skp, lcf, gsm, etc.) you can import it directly to Archicad.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Thank you!
Just a word of warning. A lot of these websites produce Archicad objects that are converted from other formats so can have many polygons and be much less efficient than proper Archicad GDL objects. This can bloat your file and slow it down. We tend to use as close as possible one of the built in objects and where we need to generate views of specific areas we use the actual objects on a different layer. It keeps the file size down.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
ml78
Thank you!
