Flared Stair?
Tom Krowka
Can AC flair a stair. That would be wider at the bottom than at the top. If not, any other way to do it other than building the stair from slab pieces?
thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
1 REPLY 1
Two ways, actually (depending on complexity).
1. Draw fill and line of travel, select both, and use Tools -> Create Stair Using Section
2. Using ArchiStair (part of Cigraph's wonderful tools). Similar creation technique, but you will more than likely have an easier time with ArchiStair.
