mukster
Floor Framing Plans
Using Archicad 24 on a Mac platform. The template I have has a framing plan for the basement, main, loft, and roof. But, I need to insert a plan in between the roof and the loft. I have no clue how to do that
4 Replies 4
You can insert a new storey if that is what you mean.
Right click on the storeys in the navigator and choose 'Create New Storey' or 'Storey Settings'.
mukster
mukster
This is what I'm trying to do. I need to add a framing plan for the loft. I currently have one for the basement, main floor, second floor, and roof, but I'm trying to add a loft floor framing plan which is in between the second floor and the roof. Got one in place, but I can't set the floor settings.
Do you have a storey for the loft?
If so great, you just need to save it as a view with the correct layer combination and model in the framing.
If not, create the loft storey and then the view.
