Font to lines and curves
Is there a way to change a font to lines and curves? I want a line type that has text in the line, example, water lines, gas lines, electrical lines, utility lines, etc. Thanks
7 Replies 7
Aussie John
try and mimic a letter/line using drawing primative like circles and straight lines.- splines wont work in line type creation
Otherwise you might need a program like freehand /illustrator which can convert all fonts to outlines and then export then to DXF
Cheers John
[/size]
You can also use the 3D text object and explode it in plan view.
The 3D text worked. Thanks
Durval
Are you sure FreeHand can export files in DXF? I've been trying to do this right now without luck...
--- www.dtabach.com.br ---
AC 28/29 BRA – MacBook Pro Apple M2 16GB RAM Mac OS Sequoia
... but don't forget to;
a) ensure that your magic wand settings are appropriate before exploding
b) 'check for duplicates' before you copy-paste into your line-type
- Stuart
PS. Sometimes I have found it useful to make the text REALLY BIG before exploding and then using a resize ...
Great tip, Mark!
I've always had to witch to AutoCAD to explode text before!
Aussie John
Well You used to be able to do it (at least import) but I just looked again now and no luck. Sorry for the bum steer
Cheers John
[/size]
