ā2005-06-01
10:16 PM
ā2023-05-23
03:35 PM
Rubia Torres
ā2005-06-01 10:34 PM
cgorgas wrote:Roof pivot lines do not plot.
1) How do I get the "pivot" lines to not plot in plot maker. The lines that show where the roof pitch is based.
cgorgas wrote:If I am understanding correctly, you can select the wall in question and the lower roof, go to 3D window, trim to roof (trim base), go back to plan view, select wall and upper roof, go to 3D window, trim to roof (trim top). Wall should now be trimmed to both roofs.
2) The attached image shows a beam above the porch. How do I get a wood frame wall with a rock face to be modeled on top of the beam. This rock of this gable wall will extend to the bottom of the roof above and rest on the lower roof to the left. I have tried numerous things but none have given me the desired effect.
ā2005-06-02 12:08 AM
ā2005-06-02 12:51 AM
ā2005-06-03 08:20 AM
cgorgas wrote:One can also think of stories as of plans.
But, the wall shows on the plan, which it should not because it is about 11+ feet in the air. Should this wall be placed on a "story above" or is there something that I am missing?
