General Pens
marco_moraz
I was 3D modelling and I needed to change the lineweight of a wall where I have a sliding door(blue line in the pic). The internal face of the wall has the lineweight assigned to the General Cut pen and I was not able to change that from the wall or door settings but only from the pen settings. My questions are:
- is there a kind of criteria when the general pens(1,21,41,61,81,101) are used?
- can general pens be used more specifically?or better leave them as already set up?
- is it possible to do this change directly in the wall or door settings?
Thanks,
Looks like the same problem with possible solution in another post?
https://community.graphisoft.com/t5/Document-Visualize-forum/Sliding-door-wall-contour-cannot-find-t...
1 REPLY 1
